Hi, I'm new to the forum, i've been working around the new steel connections add-on, and evrything has worked fine until now.
I've come across an annoying problem, when I apply a steel connection to some beams, these seem to get shorter on their y-axis.
On this example, i've used an M_S Shape S220x98 connected with the structural column by a clip angle. It worked fine, but when I open my section view, it seems to have an offset over and under it. How come the geometry of the family is being changed by the connection?
When I click on the blue "structural framing component end" tag, the beam changes to its original geometry for a few seconds, and then changes again.
I've tried modifying all parameters in the connection, but it seems strange that those affect the actual geometry of the beam family.
Thank you for your help!
