Any suggestions on creating an adjustable metal grate family. I successfully made one using arrayed extrusions, but it is too memory intensive. Something like curtain grids or profiles...
Metal Grate
Originally posted by Twiceroadsfool View PostModel pattern and/or Material, even if it's being rendered. That's even more *fine* than louvers (which I model as custom families).I'm retired, if you don't like it, go around!
Dave, generally the grate would be modeled as just a simple box extrusion within a frame. The box, functioning as the grate pattern, would have a crosshatch line model pattern applied to it with the dimensions of the grate design. The material would be transparent in shaded view, but use a material cutout for rendering purposes so one could 'see through it'. Think chainlink fencing or mesh screening.Last edited by Andrew K; December 29, 2016, 07:55 PM.Developer at Anguleris BIMsmith Marketplace.
Originally posted by Andrew K View PostDave, generally the grate would be modeled as just a simple box extrusion within a frame. The box, functioning as the grate pattern, would have a crosshatch line model pattern applied to it with the dimensions of the grate design. The material would be transparent in shaded view, but use a material cutout for rendering purposes so one could 'see through it'. Think chainlink fencing or mesh screening.I'm retired, if you don't like it, go around!
The project I'm working on has had different users create curtain walls around the building and I have noticed a difference in modelling methods and was...August 7, 2015, 08:15 PM
I'm looking for a way to model corrugated metal paneling intelligently... or rather, parametricaly.
I know many may say I shouldn't model...February 20, 2012, 02:10 AM -
I've basically settle on two approaches, and am looking for input.
1. draw all custom grids manually (more control, harder to change)
2....May 7, 2015, 05:37 PM -
We (that is me, plus two others) are busy with a renovation project for our graduation. To give you an idea, it's an old industrial site, where a few...
March 31, 2016, 10:07 PM -
Metal facade cladding made by metal profile gratings , like this ones on Libeskind's Dresden Museum
...October 17, 2014, 06:39 PM
