Ran into a puzzling problem today. I have a 3d view placed on a sheet. I modified the camera angle of that view slightly. Then I saved, synced, and went to lunch. When I opened the view after lunch, it had gone back to the original position! I repeated this multiple times, with the same result. The only way I found to fix this is to modify the camera angle in the original view, then duplicate the view and place the duplicated view on the sheet and delete the original view. Has anyone run across this? If so do you know why this would be happening?
saving 3d camera angle
I've never quite understood why it behaves like that, but 3D Views remember their "Home" orientation - as you've found out.
You have to right-click on the View Cube and select "Save View" to set your new orientation as the Home and remember it when you open the file tomorrow.Dave Plumb
BWBR Architects; St Paul, MN
Originally posted by DaveP View PostI've never quite understood why it behaves like that, but 3D Views remember their "Home" orientation - as you've found out.
I have been asked to try and match some camera views from a sketchup model almost exactly. Anyone know if there is a way to do this? So far, it does...March 2, 2012, 05:52 PM
I have a question regarding Sheet Views and their link to the View.
Scenario:
I have a Sheet with six 3D Views on it. All six 3D...May 23, 2012, 03:16 PM -
Hi all !
2012 have problem with rotation 3d view after add on sheet.
if you rotate the view after the placement on the sheet, it...July 7, 2011, 07:13 PM -
<rant>
I've been doing some renders for a housing estate, streetscapes mostly. As placing the cameras is rarely perfect, usually in-view adjustments...-
Channel: Rendering and Gallery
May 5, 2014, 12:14 AM -
I am trying to duplicate a 3D perspective view because I want to make a similar view with the same parameters in another area of the building. (I am trying...December 26, 2019, 10:40 PM
