segmented curtain wall layout
  • Dave Jones
    Originally posted by peter smith View Post
    Hello,I have to model a curtain wall in a project (see underneath link). it's a segmented curtain wall. The nods in the layout are not everythere the same. At every nod there is one mullion. Thus not a double mullion next to each other.Question: How can I model this segmented curtain wall?link layout:https://we.tl/B3vFk85jXHKind regard,peter
    the link doesn't work (for me?) this one: 2016-12-26_1213 is a true ellipse faceted curtain wall. Each facet is a singular curtain wall panel and this wall has 5 different module (cl of mullion to cl of mullion) dimensions. The type of mullion construction required is a result of the face of facet to face of facet angular difference from panel to panel. In the USA most curtain wall manufacturers have a 5 degree variance difference to allow use of a standard rectangular mullion. If your facet angles are more acute than that you will need to use a variable angle mullion or multiple mullions. Lots of stuff to consider when designing a faceted/segmented curtain wall. Be glad to help if I can
  • peter smith
    started a topic segmented curtain wall layout
