Are the GUID's exported to .dwg from Revit and if so does anyone know where in the .dwg they are?
GUID in export to AutoCad.
I am exporting a Revit drawing that contains a raster image to dwg format. When the dwg is opened in AutoCAD, the raster image is rotated or not there...October 11, 2018, 02:54 PM
We have received a 3D dwg file of that we a re supposed to work of. The dwg file is native autocad.
Does anyone know if there is a way...September 18, 2014, 09:50 PM -
I noticed PI is used wrong in calculations using DWG export option => ACA.
Maybe that is the reason that Autodesk doesn't like them to show...-
Channel: Coordination Tools
November 5, 2017, 09:02 PM -
Hi there.
When I export a sheet with a Ground floor and first floor plan the resulting DWG has both the plans on top of one another....December 6, 2011, 04:23 AM -
Has anyone had the issue where when you export DWG's and open them up in AutoCAD the page setup's are defaulted on letter size?September 23, 2011, 09:50 PM
