Just curious if anyone has tried making sticker families for slapping on their pipes and ducts. I want to take a jpeg and put it into a family that can wrap around the surface of rounded objects as well as flat, which adopt the shape of the "host" and stay associated with the surfaces as MEP systems go through editing and coordination.
Stickers Anyone?
There is an "Attaches to" option for Pipe Accessories, which can be used to put objects on the side of a pipe/duct, but if you want it to read the diameter and scale accordingly you would have to use the "Breaks Into" option and split your pipe/duct.
As far as I know jpgs can be used in tags but not mapped onto the surface of objects, unless you make a custom material of some kind and render everything.
The most practical option would be to make this as 3D Model Text, which would show up nicely in all kinds of views and exports."One must imagine Sisyphus happy." Albert Camus - "The innovator has for enemies all those who have done well under the old conditions, and lukewarm defenders in those who may do well under the new." Nicolo Machiavelli -"Things that are too complex are not useful, Things that are useful are simple." Mikhail Kalashnikov
Originally posted by Andrew K View PostI've done it as two families before. One a revolve so you can select how much of the circumference it covers, and other flat. For identification/flow/other purposes?
Secondly, how would you make the sticker display a jpeg or other image?
Glad you responded. Cheers!
Originally posted by josephpeel View PostThere is an "Attaches to" option for Pipe Accessories, which can be used to put objects on the side of a pipe/duct, but if you want it to read the diameter and scale accordingly you would have to use the "Breaks Into" option and split your pipe/duct.
I only found one post involving Eccentric Pipe Reducer and it didn't answer my question. Is there a way to have the Eccentric Reducer default to Flat...
Channel: MEP - General
June 13, 2017, 04:45 PM -
hello
i'd like to hide a part of a pipe (the part which is in the red rectangle) because i'd like to see what is beyond the pipe
in this example...-
January 7, 2019, 01:51 PM -
how exactly do u control how flex pipe is modeled? u can not draw flex pipe in 3d view.
May 6, 2013, 08:48 PM -
I am using Revit to create a wastewater pumping station. I need to use various diameters of pipe couplings/flange adaptors, but I can't find anything...
Channel: MEP - Family Creation
December 14, 2016, 04:24 PM -
Hello,
I´m really confused here with a pipe template that I have received and not sure if I´m the idiot or those families have something...-
February 17, 2016, 09:09 PM -
