Cable Tray In Section
    Hey guys is it possible to see Cable trays in section view?
    I haven't really worked with cable trays before and come across any information regarding this. For some reason in section view I can only see the cable tray center line / rise / drop symbols, I can't actually see the cable tray itself which seems bizarre.
    I've tried setting the visibility to realistic instead of hidden line and that did nothing. Am I missing something here? I assume it can't be a bad family since you can't even edit system families, is this just another hilariously unusable part of Revit?
    It's especially bad because when looking at the cable tray down it's length in section it shows a 12" wide X when in reality our cable trays are 24" wide.
    Have you tried changing the detail level of the view to something other than coarse?
    Also (in case you havent found it yet) other settings for controlling cable trays etc are here:
    (oh - just realised you can see an "X" - so prob not detail level)
    Alex Page
    RevitWorks Ltd
      This rests on two things: Detail Level and Rise/Drop visibility. This screen shot should spell out things nicely for you. Hope this helps.
      -TZ
      Tannar Z. Frampton ™
      Frampton & Associates, Inc.
        -TZ
        @Alex Page
        @tzframpton
        Thank you ... I completely forgot our view template no longer controlled that ...
        • Cable Tray Noise Barriers
          I'm new to Revit and can't find any information on handling noise barriers in cable trays. Seems like an important item to have in a cable tray design....
          June 13, 2017, 01:46 PM
        • Cable Tray Clearance Space
          What's the best way to place clearance for cable tray? I wish cable tray had an option similar to piping insulation except it added clearance space....
          May 21, 2015, 03:22 PM
        • Cabletray Using Linetypes In Plan View
          I am placing some cable tray and I would like to have it set so in plan view I can see the cable tray I use in different line types
          so say 300 tray...
          January 17, 2015, 08:59 AM
        • Cable Tray Offset-MEP
          How to chnage cable tray offset height middle to bottom
          ex: cable tray offset i fixed in 1200 but in section view it is 1150,,,...
          June 3, 2016, 07:07 PM
        • Drawing Cable Tray on an arc
          Got do draw a run of cable tray 1 metre offset from an arced wall. I've drawn a detail line as a marker. Please see image attached.
          What's...
          May 18, 2016, 03:15 PM
