Override viewport based settings in certain instances
    For example, in certain drawings, the viewport is set so that detail lines show up as halftone and we want to keep that setting. However, there is an instance or two where we want detail lines that show up regular.
    Is there a way to do some sort of graphic override that will allow this. Regular graphic override does not work since it's set in the viewport as halftone.
