Hello again every memebers here i need to know if it is possible to show partial display in 3d on specific area mean i do not have to load every time the whole 3d for heavy loading purposes here is example of other programme that show partial display i need to know this feature because sometime you need how shape of window or how shape of door look like with a material
how to make custom selection showing in 3d ?
A few ways comes to mind.
1. Go to a 3D view, then in properties, turn on the section box. You can then select the box and cut away the view. The only issue is it must stay as a box. So you can't do a wierd angle.
2. In the project browser, select the 3D view. Right click and make a duplicate. Now, open the duplicate and turn off all the things you don't want. For example, I do this and only turn on my steel framing. That way I can easily see my framing in 3D when I'm designing it. I rename this view framing and it's always there, ready for me to use without having to mess with the original 3D view.
3. Set up a camera and pretty much do the same thing.Dan
Now I like these kind of postings... Simple question, with an example. :thumbsup:
There's a few things you can do here:
1. Use a scope box. Open a new 3D View, orient it as you like and in the View Properties turn on the Scope Box. This is like a 3D Crop boundary that let's you crop the 3D view to the extents you'd like
2. Open a new 3D View and hide all elements you don't want to see. This gives you somewhat more control of which elements you want to hide but can be a lot of work in big projects.
Anyway, when done, freeze the view and you can tag and dimension the 3D elements...Martijn de Riet
i don't know what did i click, but suddenly the "invisible view box" is really small not, it doesn't expand to the whole window anymore,...November 27, 2011, 11:15 PM -
I can't figure out what is wrong with my 3D view. It has been working in the past, and on this file. Now it doesn't, but still works on all other files....February 4, 2020, 07:49 AM
Guys,
I'm not sure if I am missing something or if my expectations are too high, but I can't seem to edit (anything) in a 3D view. The...-
December 12, 2011, 02:39 AM -
I am fairly new to revit and I am struggling to figure out how to view my model in the 3-D view. I just upgraded to revit MEP 2015 and started experiencing...
Channel: MEP - General
August 22, 2014, 08:47 PM -
I was wondering if it is possible to create a view out of a 3D view. I have for example this fascia 3D view on my screen, can I somehow create a view...April 19, 2016, 04:50 AM
