Is it possible to insert a linked revit file in a similar manner to inserting a xref in CAD?
Insert linked revit file
This topic is closed.
Sure thing - Go to the "Insert" tab, and pick "Link Revit"
The below is straight from the help file... :beer:
- Open an existing project or start a new project. You will link another project into this project.
- Click Insert tabLink panel (Link Revit).
- In the Import/Link RVT dialog, select the Revit model to link.
- For Positioning, specify the desired option. In most cases, you should select Auto - Origin to Origin. If the current project uses shared coordinates, select Auto - By Shared Coordinates. See Shared Positioning. See Import and Link Options for CAD Formats and Revit Models.
- Click Open.
If you cannot see the linked project in the drawing area, do the following:
- In the view properties, for Discipline, select Coordination. This setting ensures that the view displays elements for all disciplines (architectural, structural, mechanical, and electrical).
- (Optional) To display the linked project in halftone, for Visibility/Graphics Overrides, click Edit. On the Revit Links tab, for the linked project, select Halftone, and click OK. You can select the linked model in a view and drag, copy, paste, move, and rotate it. You can also monitor grids, levels, and other essential elements in the linked project. See Multi-Discipline Coordination.
Originally posted by Munkholm View PostIf you cannot see the linked project in the drawing area, do the following:
1.In the view properties, for Discipline, select Coordination. This setting ensures that the view displays elements for all disciplines (architectural, structural, mechanical, and electrical).-Alex Cunningham
I have an Arch linked Revit file in the project. The Revit link has a CAD file linked in. I managed to show the CAD link in my project as well. The only...
Channel: MEP - General
June 18, 2014, 07:12 PM -
Hi all,
I cant select a linked .dwg file that Ive linked for use in my site plan drawing, normally I can select these files to query lines...September 15, 2014, 04:04 AM -
I've got an Architect's .rvt project file linked into a project that I'm working on and I keep selecting it by mistake and copying or moving it along...March 9, 2011, 07:34 PM
Does anyone know of a way to get a linked file's position in the current project? What I ultimately need is the position of objects contained in the...
Channel: Third party Add-Ins, API and R&D
June 2, 2011, 06:35 PM -
Hey all,
I've got a situation where I've got a linked model where I'm having to link every live view (by that I mean cut it in the linked model...September 24, 2015, 03:27 PM
