For some reason when using round ducts the taper is not loading and I get an error message when trying to change sizes. Looking at the round duct routing options there in no taper/transition loaded and it does not appear to exist in the duct library. Any help would be appreciated as I cannot progress a project until I get this resolved.
Circular Duct Taper Issues
First, go to this folder on your local drive (or, the directory in which your content was installed to) and find all the fittings you will need for your project, and drag/drop them into the project itself:
Code:C:\ProgramData\Autodesk\RVT 2016\Libraries\US Imperial\Duct\Fittings
-TZTannar Z. Frampton ™
Frampton & Associates, Inc.
Hello,
I am trying to make a custom tee and I have problem that I can't solve.
When I make a tee from an elbow it works fine...-
Channel: MEP - Family Creation
March 31, 2014, 11:19 AM -
Afternoon,
No matter how many tutorials or forums I have read I still can't get this to work. I'll set justification when drawing but I...-
Channel: MEP - General
June 25, 2014, 06:51 PM -
I have a 700 x 700 duct and have another duct 700 x 300 above, which i want to drop down which i would like to connect it into
i cant seem to do...-
December 4, 2014, 11:44 AM -
I am using Revit 2017.
I am trying to connect a duct from a shoe to another existing duct which has a different offset but...-
March 8, 2017, 03:09 PM -
I have a case where a piece of rigid duct is replaced by number of (could be 4,5 or more) flex ducts. I have to use a round duct tap....-
April 27, 2018, 05:49 PM -
