Hi All,
Just looking for some help with 'proof of concept'. I have run into this situation 4 times in the last week and each time I have dead ended :banghead: because of what I am sure is a very simple problem.
See attached, but the concept is:
For example, I want to take the 'Mark' value of a filtered selection of curtain walls and set this value in the 'View Names' of a filtered selection of elevation views.
If I am doing a simple get.parameter / set.parameter I have no problems, but once I introduce the nodes to filter, I get lost.
Thanks in advance for any tips & guidance.
- We need to get a parameter value from one category, but only some of them, so this means we need to filter our selection.
- We need to then take these filtered values and set another value in another category.
- Again, the second list is also filtered.
- I can filter both lists, but then getting the nodes to work to SET the parameter just never works for me.
