there is this one:
What Revit Wants: Collect Elements in Rooms Across Linked Files, and Write Room Data Directly to Elements or List to Excel
but it seems so complicated to work, even dynamo keeps crashing very often when i open it and try to get my head around it
Scheduling Doors in LINKED model with Rooms in HOST model
And then this ?
Topic: Geometry Intersect and Geometry DoesInterect not working | Dynamo BIM
The end of the post has the solution ?
OK I got this: https://dynamonodes.com/2016/10/28/h...-project-link/Last edited by kamranmirza; December 13, 2016, 05:23 PM.
Thanks Daniel. They say that just giving a direction to the hungry is enough, they'll go feed themselves. Hopefully your direction will be enough for me
Steam Nodes can pull the Rooms from a link files but you wont be able to write it to the From/To Room parameter. I stopped using those a long time ago as they are not reliable(they won't update after the schedule as been created)
once you have the Rooms then you can use Intersect to find the geometrical intersection. Might get a little tricky with doors but it works
We have multiple house units that repeat and so we are linking in house types and using them repeatedly for the different houses.
Now, the doors are in the linked house type models and we have made the rooms in the HOST model to give them individually identifiable room numbers.
Our door schedules use the "to room" parameter and the "room number" to identify the location of the doors. Revit doesn't allow the doors and rooms to be connected across linked models.
Has anyone come across a solution using dynamo ?
Thank you in advance.Tags: None
In the year 2016 we find Revit is still utterly clueless about the relationship between doors and rooms. We have this quirky documentation habit of using...
Channel: Blog Feeds
January 6, 2016, 04:15 AM -
I am working on a very huge project that is linked with multiple models. I am trying to create a door schedule with from/to room data in host model and...May 15, 2020, 03:31 PM
We have been working on a large scale residential project, in which the suites were formed as groups. Recently, we changed all these groups, and in the...June 27, 2011, 04:08 PM
I'm trying to chase down some Redundant Rooms (just had to Bind two models)
I've got a Room Schedule which isolates Redundant/Not Enclosed Rooms,...January 28, 2014, 04:52 PM -
Hey guys i have been searching far and wide and can not find the answer to this workflow-
This should be really basic, the project is a multi-story...December 31, 2013, 01:05 PM
