Ok, I give.
I've (finally) got a curtainwall in an opening surrounded by precast panels.
I want to select all the elements of that curtainwall to copy it to the next floor up.
I can select all the mullions or all the panels but can't seem to select the ENTIRE curtainwall.
This is in 2012...which I just started using. In previous versions, when you tabbed enough, you'd eventually get what I'll call the "centerline" of the curtainwall - selecting that grabbed everything and you could do whatever you wanted with it.
After tabbing oh...let's say 237 times...I'm convinced that "selection" isn't there anymore.
Can someone PLEASE enlighten me?
I'm nearly out of Advil and I doubt drinking will help.
Also...how do you delete the damned thing?
Having tried multiple times to get this SINGLE curtainwall right, I never could delete a "wrong" attempt...I could select the glazing (before adding a grid or mullions) but the delete option isn't available....had to UNDO everytime.
