Using a Curtain Wall type as a panel nested in a different type of curtain wall
    I know this sounds convoluted but I am currently trying to model a window wall system across a high rise building. My solution thus far has been to:
    1. use a curtain wall rather than a window wall at every floor
    2. set a curtain wall that stretches to the extent I need across the entire facade
    3. Set the panel type of this curtain wall to a preset "window wall system panel"
    I initially created a family for this panel, but the joins between each panel (especially at corners) was very inaccurate. My solution was to create a curtain wall type that acted as a window wall system, and use that c.wall as a panel in the overall curtain wall. This would allow me to set the h grid of the panel to the height of my bypass panel for the window wall, and also allow adjacent panels to delete overlapping mullions.
    The problem I am facing is that not all floor to floor heights are equal, so the h.grid of the panel would have to change depending on the floor to floor height. Is there anyway to make the grid of the panel I've created offset from its top constraint, rather than having it stay at the same height every panel?
    can you post a screen shot of what you are trying to accomplish? I'm a curtain wall detailer and I'm standing on my head trying to figure out what you're doing...
      Pictures would help to understand your problem.
      In the mean time, have you tried under type properties of a nested CW to set horizontal grid's layout to 'fixed distance' and then in properties palette under horizontal grid set justification to 'End' and set 'offset' to a desired distance ?
      Revit add-ins: SolarDaylight analysis​, Purger (delete UNUSED and selected line patterns & line styles, find & delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags), View Filter Manager (with bunch of other features) at Autodesk App Store, View Filter Manager ML
        Ah, setting the offset and justification worked! Moving forward:
        1. Is there anyway to set the justification to end, and offset to desired distance (in this case, slab thickness) as a type parameter rather than an instance parameter
        2. The nested c.wall needs to have both, a bypass, and a glass panel when created.. is there a way to create the c.wall so it is generated as having both?
        This is the nested c.wall isolated, as while as what it looks like nested in a test facade c.wall
        the top panel in the left image serves as a bypass, and would have to be different than
          I've tried replying a few times, not sure why it's not coming through.
            For new users, the first 5 posts must be approved by a Moderator before the show.
            Helps us cut down on spam and phishing posts. You might be surprised how many of those we blow off and no one ever sees.
            The good new is: one more and you're in the clear!
            Dave Plumb
            BWBR Architects; St Paul, MN
