Good Morning/Afternoon Evening however this finds you!
I have an issue where I am placing columns the preview on the mouse cursor is not visible.
I have narrowed the error down to the fact that my project base point is a few meters below the level I am trying to place the column at.
I have an existing building with a project datum of 29.515m AOD
Ground Structural Slab Level is another 22.054m above this again and my works starts on 6th Floor.
So all in my first column will be placed 42.597m above the Project Base Point.
In Capture 1 attachment you can see the error.
Please see the link aswell:
Revit OpEd: Structural Column Preview does not Show
it appears that the error has occurred for others and for some reason not addressed by AutoDesk yet.
I will try any suggestions to see if we can get around this.
Thanks in advance!
James
UPDATE:
My current fix is to
1. Open the model
2. Place a column on a level @ 0,00 (Project Base Point)
3. Open 6th Floor
4. Place a column (Outline not shown)
5. then the outline becomes visible
Steps 1 & 2 & needs to be done every time the model is closed and opened
Steps 4 & 5 needs to be repeated per level!
Thanks in advance!
James
UPDATE:
1. Open the model
3. Open 6th Floor
