Hi im trying to export steel structure to SCIA Engineer 2009 via IFC 2x3,
the problem is framing (beams and bracing) are exported as physical model instead of analytical. So instead of joining the column in the analytical point all the beams hang in the air. Check out the screenshot i attached to this forum.
There are no options on the Engineer side so i have to modify the IFC settings (mapping etc) on the Revit side.
Anyone has some suitable IFC Class Mapping file or default template for IFC?
