I'm working on a couple projects for one client and have to meet some client standards and am a little stumped on how to get the text to work to match. In the attached image the C-01 sheet is from civil (CAD) and the A001 is my sheet (Revit.) They require RomanS which I have but I can't get the text to be any heavier. Text is the correct size and I have it checked to be bold - is there anything past that I can do?
Text Properties - Consistency between Revit & CAD
Good luck with all that.
Fun to hang out at Aaron's the other night btw.Tannar Z. Frampton ™
Frampton & Associates, Inc.
Originally posted by cellophane View Postand they are using SHX... super. time to play with different fonts and see what is close.
Just to tag on the end, I was asked to try and re-create similar RomanS (LWeight 0.2mm) label. RomanD Bold was the closest I could get if you have trouble changing opinion.
- - - Updated - - -
User Defined just declares how many rows there are. I *think* the only thing you can do is adjust the font size in the body, to make the rows expand or contract. But this entire thing is asinine. Again- If its the client making up these standards, ask them for the settings that they would like to see? Otherwise, explain to them that its not a configurable option in the software.
- - - Updated - - -
Why is this forum being such a piece of crap?
Originally posted by Twiceroadsfool View PostBut this entire thing is asinine. Again- If its the client making up these standards, ask them for the settings that they would like to see? Otherwise, explain to them that its not a configurable option in the software.They do have a rather lengthy standards document but it only relates to CAD and never gets into other software, probably because it is a municipal utility and 99% of the work they deal with comes from Civil.
Thanks for the help :thumbsup:
Hello, Can anyone help me with this, plz?
I have a CAD link into my Revit file that contains text... when printing Revit sheets into PDF, all text...June 9, 2021, 08:56 AM -
I'm using the same font (ISOCPEUR) in both my CAD drawings and Revit file.
Somehow when I import (or link) my CAD drawings (which contain some...October 18, 2012, 10:52 PM -
Recently took a new position at a new firm and I'm essentially in charge of leading the conversion to Revit from CAD, since Revit is essentially all I...
March 2, 2017, 03:13 PM -
Any one have any idea what would cause the text within a linked Cad drawing to only appear when scrolling? As soon as scrolling stops, the text is gone...April 2, 2015, 11:53 PM
I have a 24"x36" sheet of specs in auto cad. how do I add those notes in Revit? also will I be able to make any modifications to the specs once...August 29, 2014, 12:56 AM
