Does anyone know why when I print a full set of plans to PDFs and combine it in a single file, it prints everything correctly. However, once the printing dialog for adobe PDFs closes, revit tries to print each sheet individually and i have to start canceling it sheet by sheet?
Pdf print bug
This topic is closed.
Got this issue sometimes, my answer is that I never combine sheets with Revit but do it with the pdf printer (PdfCreator for instance).
For memory, options in the pdf printer should be set to reduce dpi for the document.Julien
P. DAC
I have been printing fine from this file, except for one floor. I prints light and manipulated, walls are missing, trees transformed. I have never run...April 28, 2013, 02:13 PM
Sometimes when I select sheets to print to PDF (and have combine into a single file selected) Revit will print everything to that single PDF but then...May 9, 2012, 11:28 PM
Like in Auto CAD is it possible to rotate the orientation of the print so that we can avoid paper waste.
Can a portrait sheet...October 16, 2013, 09:22 AM -
Hello,
I'm printing about 100 sheets to pdf, and the client wants them printed individually rather than one single file. Does Revit print so that...November 30, 2011, 04:12 PM -
Hello. When I print the sheets to pdf the curves lines are not correctly displayed.
Anyone knows where is the problem?
Thank you....February 12, 2017, 03:50 PM
