So every door family in our office has a dozen shared parameters in it. Everything in our template it setup fine, however whenever we create a new door, or use a door generated from a consultant / design architect.. it is lacking those parameters and we have to go through manually and generate each parameter one at a time for every door. Does Dynamo work inside the family environment?
For instance, I'd like for a door to have a "Frame Rating" parameter.
Discipline: Common
Type of Parameter: Text
Group: Identity data
Instance Parameter
or
Frame Type
Discipline: Common
Type Parameter
I've seen a few methods that circle this topic, but general consensus (at least in the past) is that it didn't work)... any suggestions?
Discipline: Common
Instance Parameter
or
Frame Type
Discipline: Common
Type Parameter
