How to make specific parameters within a label invisible.
    Hey guys, I'm new here.
    This may be a simple process. Please help me as soon as you can. I would greatly appreciate it.
    http://i.imgur.com/TMxfMEq.png
    So I'm making a window tag for my project. Within the instructions of my professors assignment, we are to keep the type mark visible but every other parameter invisible.
    Within the properties, there's a check mark for "visibility". I unchecked it but when I loaded the tag into the project everything became invisible! Is there a way to keep the type mark visible while making the height, width, and etc invisible?
    don't put all of the parameters in the same label. the ones you don't want to be visible, either uncheck visibility or associate with a type parameter that is off for the type.
    look at the out of the box room tag to get an idea as to how you could use Y/N visibility Type parameters and multiple Types inside your tag family.
