Hi all,
Just wondering if anyone has any experience in this field of using point cloud images to integrate or create revit models?
I have a few basic questions in relation to this:
(and no this isn't for an assignment or something like that even though these questions might seem a bit "template")
How efficient & effective is it?
What sort of situations would you say benefit the most?
How long does a scan take? I realize this is hard to estimate as it would be based on size of what you are scanning, but say a low rise factory or something, 1 level, large open space with lots of equipment that you normally wouldn't model to such detail due to complexity etc.
Is there some kind of X hours per Y cubic meters formula or something that can be used to roughly estimate how long a scan will take you?
How long realistically, does it take to import a meaningful model from the point cloud images into revit?
And what sort of processing power do I need to make this work and not take days to import or choke up my models to be unworkable?
What about UAV drone surveys? Anyone used these with much success for revit?
I know also that it is possible to scan the exterior of the building with a drone. Ideas on timeframes there?
Thanks for any help you can give there, even if its based on an external consultant you engaged to do this kind of work or similar.
Cheers
Cheers
