Any suggestions on slopes roads in revit? Easiest most effective method please.
Slopes roads
Hi JasonNelson92,
Did you already try with the "Site Designer" module?, rather than roofs and slabs (which are good ideas), you can use roads, sidewalks and other elements which will follow your toposurface simplifing the task, I found that the site designer is not so complicated to work with but you need time to control the final result, I'm also work with Building pads which let you put a slope to the pads and that gives you the opportunity to model roads too but there are the toposurface points drawback which will follow the pads, hope this helps, regardsLast edited by Andres Franco; December 6, 2016, 08:25 AM.Andres Franco - Architect - BIM Coordinator
E.A Poe
I often use pads (instead floors) for paths around residential slabs so i can cut the topo with them and it seems fairly clean. On occasion i would have...May 20, 2017, 03:17 AM
Hi, I have site topography that is irregular and I need to make streets and pavements with floors ,How I can do it in way that is not painful because...October 19, 2016, 02:13 PM
Hi all,
Does anyone have any good suggestions for modelling roads and footpaths on uneven topo surfaces? My topo surface slopes down roughly...September 10, 2016, 10:54 PM -
Hi everyone,
I've not been using Revit for long and have jumped in the deep end somewhat with a huge site model. I've been using 3ds...June 27, 2014, 10:06 AM -
Hi.
Can anybody show me a way to put a road with inclination on a toposurface?
As you can see I have put a "Building Pad" which...June 12, 2014, 09:46 AM
