Hey guys, how are you doing?
So, I've been working with Revit MEP for a while and so far I've been using different templates to coordinate different disciplines. For instance, I use one template for the entire Electrical system, another for the entire hydraulic, sanitary and ventilation systems, another one for the architectural project and so forth so on.
By doing so, I can keep a record of everything I update in each of these templates and synch them as well, having a perfectly coordinated workflow.
However, I was wondering what would happen (and I believe that this is precisely what happens in a daily basis with huge offices) if I received a .DWG or .RVT file from an architect or engineer and then I had to create the MEP system.
Normally, I'd delete all the fixtures and add my own fixtures to it so I could run a pressure loss analysis, flow analysis, etc etc etc. But what if the architecture or the engineer wanted the model to be a perfect match using exactly the same fixtures he used?
Well, in this case I realized that I'd have to use the added fixtures and adapt them (adding up hydraulic connectors, adjusting the CWFU/HWFU units, etc, etc, etc). But I can't just do that with a model that I had linked. I have to use the COPY/MONITOR tool to "import" it on my model and then edit the family accordingly.
Once I do it, I can modify the family as I please - but I can't delete it. I mean, if someone had placed the wrong fixture, for instance, in the Bathroom (used a sink instead of a lavatory, or a shower instead of a bathtub), how could I modify it if the only thing I can do using COPY/MONITOR is, as it says, COPY AND MONITOR?
Can anyone explain to me how it works? I mean, this COPY/MONITOR thing? Is it possible to delete something from a linked file?
Thanks everyone!
Thanks everyone!
