I am modeling a curved exterior stair, and need the stringers on each side to be different depths. Does anyone know if stringers can be manipulated individually? I know that I can change the type of stringer (profile, etc.,) but I haven't been able to modify the stringers individually - if I change the size of one, the same values are applied to the other. Any suggestions.
Modifying Stair Stringers
Can this stair be done in one stair sketch? I did this with 3 separate sketches...one for each stair run. The main problem I have is that I can't get...October 28, 2011, 03:10 PM
Guys,
For our construction process we use precast stairs. In this particular case we are not only creating the precast 'main stair flight',...April 17, 2013, 11:57 PM -
Well I'm struggling with Revit 2018.3, there are a lot of things going bad since I've started to use it, today Stairs by sketch don't want to work at...July 4, 2018, 12:44 PM
Which type of stairs do you prefer to use? Stair by component or stair by sketch? What are good and bad sides of both? I noticed that when I use Stair...May 6, 2014, 03:16 PM
I am creating a curved stair 8' wide going up 20' in elevation with 3 landing for a museum. I can create the stair in one project and it comes out fine....March 12, 2013, 02:55 PM
