How could you add a robe hook to the back of a bathroom door and have it visible in both an elevation view (door closed), and in a plan view (door swing open)? I can get it in one or the other but not both.
Robe hook on back of door
If you are using the OOTB doors..It will be just the closed door where this will work, as the swing elements are 2D linework.
You would have to place it on a door that has a 3D swing to show on plan and elevation, but that would take a lot of work at printing if you want to show the door open on plans and closed for elevations.
I suggest sticking with the elevation view and not show it on floor plans. Besides, they are easier to tag and show height in elevations.Michael "MP" Patrick (Deceased - R.I.P)
Guys,
Tell me how your firm does with door clearance.
EX) for ADA Residential Unit, we Typically have show door clearance in hidden line...February 9, 2016, 04:44 PM -
I have a 1219 w door that has also included the family a door frame (51 each side the door. The way this is currently drawn, it also has an allowance...August 20, 2020, 01:39 AM
I am working on floor finish plans and the door I am using does not mask the floor tile pattern below. I have not located a setting in visibility and...June 14, 2012, 05:03 PM
Hello,
How do you stop walls going through the door. I know I can set the cut plan about the door, but then everything else I want on the...July 3, 2015, 12:33 PM -
Ill try to explain this as best as I can. Does anyone know if there is a way to get door swings to appear at a 45 degree angle when they are inserted...
September 14, 2015, 08:22 PM -
