Ceiling Missing
    Ceiling Missing
    So I've been reading up on all the possible reasons I can't see a t-bar grid, and still can't find the solution. I'm using an IFC link from the Architect to draw on in Revit and I'm fairly new to the program.
    Any suggestions? I'm tired of banging my head on this one.
    -Thanks
    Can you see the element when you open the IFC with a viewer (Solibri for example)?
    If it's the case, what category is it under?
    - - - Updated - - -
      Same issue...
      Another person in my office is experiencing the same thing with Revit...cannot see the ACT ceiling after swapping it out from a generic ceiling element. Any ideas?
        Can you see it if you cut a Section through the Room?
        My first guess would be that there's no Surface Pattern applied to the material of the Ceiling's Finish Layer.
        Dave Plumb
        BWBR Architects; St Paul, MN
