Revision Schedule Edit
    How could I edit the revision schedule per sheet w/out adding rev clouds and then going into the schedule.
    What are you trying to accomplish?
    The whole purpose of the Revision Schedule is to track clouded changes on Sheets.
    But if you're trying to do something like have "ISSUED FOR SD" show up on a lot of Sheets, you can go into each Sheet's Properties and check the "Revisions on Sheet" drop-down. But you can only do that one at a time.
    Frankly, I think that's way too much work to check every individual Sheet, so we put a dummy Cloud off to the right outside the printable area.
    - - - Updated - - -
    Dave Plumb
    BWBR Architects; St Paul, MN
      We add several revisions per sheet in our mechanical layouts. Also clouds and tags are rarely used. So for the simplicity of just adding text to a revision schedule, where would I start.
      Here is the rather long sequence I'm using to add a revision. View_Revisions(add date text and initials select none under show)_Annotate_revision cloud_select the revision I entered. This seems complicated just to add "Re-routed AC Duct Line 2" in a Revision Schedule.
      Thanks for any and all help.
