For some reason my files (every type) have turned blank "white" Has anyone seen this before and perhaps know a fix.
Files appear white in job folder.
Do you still have Revit installed? If you do do they open ok? I haven't seen it with Revit specifically, but I've seen it happen when a file type doesn't have a program associated to open it. The times I've seen it opening one file (and associating a program if needed) will cause the rest to adjust.Julie Kidder
Architect + BIM Director
Originally posted by jmk View PostDo you still have Revit installed? If you do do they open ok? I haven't seen it with Revit specifically, but I've seen it happen when a file type doesn't have a program associated to open it. The times I've seen it opening one file (and associating a program if needed) will cause the rest to adjust.Last edited by JD003; November 25, 2016, 11:52 PM.
Hi JD003, if for whatever reason Windows has disassociated the .rvt file type with the revit executable then just right click after selecting a revit file, then go to 'open with', go to revit.exe in the choices or by going to open with other, etc., and select revit.exe as the executable to open with and the association will be remade. Oh, and don't forget to tick the 'always open this file type with' box.
This may have happened due to a windows update, installing another Autodesk exe, etc., but it's an easily recoverable situation.Kamran Mirza
Ok guys, here is a tough one (I hope not).
Recently I cant open a file the usual way, buy clicking on open button or any other analog command....January 19, 2017, 10:23 PM -
I am currently working on upgrading our office to 2012 and a few of the template files are giving me the attached error.
I have checked...May 31, 2011, 01:15 PM -
everytime i open a file be it a drawing file, a revit family or anything to do with revit, it opens up a new session of revit.
now, day...August 12, 2011, 12:44 AM -
Hello all,
We have recently started using Revit 2013 at work and all file types had become unrecognised (ie, .rvt files were unrecognised,...August 29, 2012, 12:41 PM -
Not sure if I should post this here or in the new WDF thread, but check out this error message:
Doesn't look all that unusual, right?...May 28, 2013, 09:35 PM
