Applies to: - All Verticals
New Feature / Problem:
Allow/create an option to set "Solid Fill" filled regions as transparent, in addition to opaque as is current, in the same way that it can be done with other fill types in the family and in the main revit model.
Current "Solid Fill" filled regions in families only have an opaque option. This causes problems in families such as title blocks and annotation families when you want to show detail lines or images over a filled region.
Workflow:
Edit Type > : Transparent
Benefits:
Allow drafting & image objects to be seen in front of "Solid Fill" filled regions
Attachment comments:
Do you agree with the above?? Use the "RATE THIS THREAD" tool at the top right corner to express you opinion.
Workflow:
Benefits:
