How can i construct a "chord-geometrie" (axis) I would like to have that the point is the center of both reference-lines. it is driven by the angel and(or) by the dimension. How is the workflow to create this conditions
I am curious as to how people are dimensioning to a center mark of an arc i.e. I have an arced wall and I have a radial dimension for that wall shown....
Received a question via email asking why Revit seemed unwilling to assign a Shared Parameter that used the Duct Size type to a dimension string. Here's...
That parameter name seems a bit like the Department of Redundancy Department. It lets us choose between three kinds of dimension behaviors: Continuous,...
Is there a way to get a dimension string to snap to the center of a created curtain wall? We often use curtain walls and customize them, to use as storefronts...
