I am trying to create extrusions that i can rotate in all 3 directions. In following several directions of nesting the extrusion and applying the rotation by means of a reference line that has a rotation parameter. No problem so far. Direction then indicate to set the workplane of this nested family to the reference line. No matter what i try/pick/etc i can not get the reference line selected as the workplane. What am i missing in accomplishing this.
3d Extrusion Rotation
Hello I am having a problem rotating something created in the family editor and then inserted into a project.
I can try toggling the workplane –based...-
January 25, 2019, 06:36 PM -
This is my first post, so I apologize if this may be in the incorrect place (or a bit wordy). I am trying to incorporate roof curbs as a nested family...
Channel: MEP - Family Creation
March 13, 2019, 02:53 PM -
I have a solid_child face based family nested in a solid_parent family. I can rotate the child in any angular direction except when I hit zero degrees,...
December 14, 2012, 07:34 PM -
Hello,
I created a generic angle iron family. Then loaded it into my project and noticed I can't rotate it if I am in a front section view....-
January 2, 2018, 03:20 PM -
I have a nested family that I need to be able to control a height angle and a rotation angle on. I set the paddles up and have an angle parameter so that...
August 3, 2018, 04:58 PM -
