[All Verticals] - Select text / characters (CTRL+FIND)
  • katewood1989
    started a topic [All Verticals] - Select text / characters (CTRL+FIND)
    Applies to: - All Verticals
    New Feature / Problem:
    Similar to a webpage or a PDF, when you open it, you can do a CTRL+FIND, and find any text or keyboard symbol in the view/page.
    I know that there is a find and replace tool but its not the same, it's very limited. This would be something where it selects any text and highlights it, whether it's text in a window tag, a number in a door tag, a note, anything that contains said letters or other keyboard characters.
    Why do you need this Feature / Why is it a Problem:
    There are a lot of times when this is handy, especially in a large project where there are a lot of letters, numbers, etc.
    Workflow:
    I am working on a window schedule for instance, and I want to see how many times the tag W85 is used for example. So I would like to do a CTRL+FIND and it would highlight all the instances that W85 shows up.
    Benefits:
    I wouldn't' have to convert the view to a PDF
    Attachment comments:
    Do you agree with the above?? Use the "RATE THIS THREAD" tool at the top right corner to express you opinion.
