our structural consultant likes the floor plan s to only show the stud layer of the wall. is there an efficient way of doing this? right now I am exporting to dwg and in AutoCAD I am deleting all the lines that represent either the sheathing or finish layer. which is very time consuming.
s for consultants export to dwg
Originally posted by ledgewood33 View Postour structural consultant likes the floor plan s to only show the stud layer of the wall. is there an efficient way of doing this? right now I am exporting to dwg and in AutoCAD I am deleting all the lines that represent either the sheathing or finish layer. which is very time consuming.
You can place each Wall Function (Structure, Substrate, Thermal/Air Layer, Finish 1, Finish 2) on it's own layer from the Modify DWG/DXF Export Setup. Then isolate, delete, and purge the offending layers in AutoCAD.Greg McDowell Jr
about.me/GMcDowellJr
Hello all.
I am setting up Revit 2014 inside an architecture bureau that normally uses AutoCAD. The bureau has their AutoCAD layer standards...November 15, 2014, 08:40 AM -
I am setting up an Export Setup file for .dwg s to consultants,...is there any issues that anyone is aware of that I should know about going...May 10, 2012, 04:48 PM
Hi there. I need to export 2d views to dwg for my collaborators, and the gypsum interior partition walls need to look like this:
That horizontal...July 26, 2016, 08:03 PM -
I'm a new member of the forum. I use Revit for several years now, but I had to make a export setup list for the first time.
October 13, 2020, 07:37 AM -
Hi everyone
I have a really important question.and i would be really thankful if u could help me.
I have to export layers from revit to dwg...February 11, 2019, 09:54 AM
