Return en element to the main model after adding to an option set.
  • danezeq
    Thanks.
  • elton williams
    You also wont be able to delete an option or a set unless you revert to 'main model'
  • jmk
    You can't delete the primary option. You either need to delete the entire option set or Accept Primary. Accepting primary will return all elements in the primary option to the main model.
  • danezeq
    and then is it possible to delete the option? the option DELETE on desgin option is grey out.
  • cellophane
    Copy the element, change to your option set to main model, then paste to same place.
  • Return en element to the main model after adding to an option set.
    Return en element to the main model after adding to an option set. is it possible?
