You may remember a few posts about the Revit.ini file and Revit 2012: Deploying Revit 2012 with a Customized Revit.ini file Revit 2012 Network Deployment Utility: Custom Revit.ini Settings and Content Supression Who moved my Cheese (Files) ? - Important...
Revit Clinic: And the Revit.ini file strikes again...
In 2012 Revit products, things got moved and switched around when dealing with the Revit.ini file. Who moved my Cheese (Files) ? - Important File location...
Channel: Blog Feeds
July 11, 2012, 03:45 PM -
In case you didn't read the readme for UR2, UR2 for 2012 Revit products patches content files that are part of your installation. Some of you might not...
Channel: Blog Feeds
September 29, 2011, 03:40 PM -
Back in the day I was able to go in and change my INI and the next time I launched Revit the actions would take place.
Now when I go in...July 12, 2011, 03:26 PM -
In localized (non-English) versions of Revit 2012 products, you may find that some icons on the Ribbon are not displayed correctly: The following versions...
Channel: Blog Feeds
July 13, 2011, 11:11 PM -
If you have seen it yet, UR2 is now available for Revit 2012 products: Revit Architecture 2012 Revit Structure 2012 Revit MEP 2012 You can also view the...
Channel: Blog Feeds
September 28, 2011, 09:11 PM -
