Spot Elevation Family
    I attached an image of what I want to and where I think I should be able to.
    In the Symbol parameter, default is (none) but where do I set it to something? :banghead: I can't figure out how. I think that is where I should be placing my datum symbol.
    Thanks! :wine:
    ~Elisa
    BIM Director, AC Martin
    What template have you been using ? Are you positive that a Spot Elevation Annotation Symbol is loaded ito the project ?
    (Look for it in Project Browser > Families > Annotations)
    Otherwise, you could try to post your .rvt file (Make a copy and delete/purge everything not needed)
      It should be there, did you purge the "target filled" family by any chance? it should be under Annotations - Spot Elevation Target filled w/ extensions
      Juan Carlos Moreno
      Sisley Cosmetics
        Very weird, the image I showed has the spot elevation tag, but in my families I can't find the Spot Elevation family! And yes I think I did purge the "target filled" family. I figured I could chose the Level Head symbol.
        So I'm confused how is it that I am able to place the "Spot Elevation" and not have the family loaded?
        Edit: I see what it is, the Spot Elevation families are the symbols, the Tag (as I've called it) is a System Family, it won't be listed. Sorry I had a brain freeze! But thank you I see now what I need to do. Thanks for you help!!!
        ~Elisa
