Half on an elevation with shadows and the other without
    Hi everyone!I'm doing a half elevation half section view. I'd like the elevation part to have shadows while the section part should remain "clean".Is this possible?Thanks in advance
    Create Two Views (which you'll have to do to get the Section anyway)
    Place one on a Sheet, then drag the other one onto the Sheet.
    You should see a green dashed line when they are lined up with each other.
    You may need to have the Crop Region turned off while you're placing them. Once they are in the right place, just go back into the View and turn the Crop back on.
    Dave Plumb
    BWBR Architects; St Paul, MN
    Loading...
