Don't Think: Revit Server Installation/Updating & Mosaic
    A Revit Server post to leave you with as I head out on vacation...
    I recently ran into an issue with Revit Server that also caused another large firm quite a bit of distress. THe problem is this:
    1) User A installs the Revit Server application onto the server OS/hardware.
    2) User B goes to either update the Revit Server applicaiton or un-install. If the user runs the Service Pack EXE it reports the program cannot be found. If User B goes to un-install the Revit Server application the Add/Remove Programs dialog does not display the Revit Server application.
    3) User A logs into the server and can update Revit Server or Un-install the application from the server.
    So, the short story here is that if you only use Windows User accounts that are associated with specific users, then when it comes time to update or remove Revit Server you need to know who originally installed the software on the server. If you have a generic "Admin" account that can be used then that is your best chouice when it comes to installing and patching Revit Server. This "bug" in terms of Revit Server seems to likely be related to the increased security restrictions applied by the Windows 2008/7 environment(s) and how the installer for Revit Server works. This issue has actually exsisted since 2011, so it is not related to the new 2012 installer. In terms of getting it "fixed" I'm not holding my breadth as this issue is likely well embedded into how the software is installed in the first place.
    One other note, Autodesk Labs has a new project called "Mosaic" check it out, I think it has some interesting potential if people take to it. It is kinda like a "Google" reader for AEC Tech geeks.
