Hello, producing this rendering but not satisified at it. (still using revit 2008 to modelled and render). how can i make it look more realistic? is it the programs i am using is too old? .. thanks for help and suggestions.
More realistic rendering?
It's not necessarily about the age of the program. 3ds Max 2008 would give you more potential to make the scene more realistic. I believe Revit's rendering limitations are a conscious decision to hide all the "rendering nastiness", as photorealistic rendering can become truly daunting.
There's plenty of tutorials online if you want to go down that rabbit holeChris Ellersick
Even upgrading to Revit 2012 would result in a better image. Photoshop will be your friend otherwise.RB Cameron, AIA, LEED AP, EDAC, NCARB
Architect - Parametric Designer - Visualization Instructor
Download Healthcare Revit Models
Download Revit+3dsMax Models
I think 2008 had Mental ray, if so, upgrading to 2012 wouldn't do anything. Something looks really odd about his materials. Like its a shaded view, not real world materials or he is just using colors and not image maps and custom materials. I suspect upgrading alone will do you no good. You need to swap out your materials for some image based materials.Scott D. Brown, AIA | Senior Project Manager | Beck Group
I remember 2008. <shudders> It had Accurender. only. The unholy offspring of a potato shredder and an Apple II.
Revit : Rendering in Revit Architecture 2009 This was the greatest day of April of 2008 for me when it released.
Its honestly not THAT bad of a rendering should you put a little time in photoshop to adjust the levels, HDRI that puppy and play with the colors and contrast.RB Cameron, AIA, LEED AP, EDAC, NCARB
Upgrade to 2009
You should probably upgrade to Revit 2009 ,if you want to stick with the old GUI , there is some significant improvement with the rendering,
here two examples done with Revit 2009, no photoshop, basic material, basic lightning, medium setting,
if You want, you send me the project, then I hit render with Revit 2009 to see what come out,
If the project can be share,
could miss some texture,soo
cheers,Attached Files
I'm having some major rendering problems in Revit (2012). Rendering a draft view takes a little over 4 hours. Rendering with artificial lights on, puts...
Channel: Rendering and Gallery
May 12, 2011, 07:07 AM -
We've been using revit to make quick renderings of projects which works fine. We now need a high resolution rendering to be used on a construction site...October 8, 2018, 01:00 PM
Hi , Thanks to all people here giving me their suggestion and tips to improve my rendering outputs like cliff collins Dzatto, sdbrownaia, Munkholm, and...
February 19, 2012, 10:48 AM -
I have Dell T1500 Workstation with following configuration.
Intel i5
4GB Ram
Windows 7 Pro 64bit.
1GB Quadro600 Graphics...-
Channel: Hardware and Infrastructure
December 5, 2011, 03:32 AM -
How has everyone been dealing with network rendering?
Does Backburner work for Revit? Is there another alternative?
We are a small...-
July 12, 2011, 08:46 PM -
