Legend Component x view range
    Hi folks,
    I'm having one problem that I don't know how to solve. Some of my door and window families aren't appearing in my Legend... The wall where they're hosted is above my component, so I'm not able to see them.
    Last edited by Alfredo Medina; August 11, 2011, 11:54 PM. Reason: Replaced in-line images with attachment.
    Yup, cannot see this either... Those inline attachments won't work for me.
    What I can say is this: the legend is created with default window placement. I think that if you go into the family, heighten the sill height, reload and override parameter values it should clear up. Otherwise try to replace it afterwards.
      I found the solution to this problem... It is determinated by the ref. plan. view in the family, and we can correct this changing the default sill heigth; if its cutted by the view range of family plan view, is ok, if not, it's not ok.
        mddradvies, thanks. I didnt saw your answer, but its ok. That is what I discovered here.
