Is there some clever way to have the number of sheets counted and displayed (i.e. Sheet 6 of 25)? Maybe some sort of formula for a parameter in the title sheet?
You sure can, you will need to add "fields" in your title block.
Randy - Could you elaborate a little on that ? What do you mean by "fields" ?
Hope to learn something new here, but to the best of my knowledge, Revit do NOT know how many sheets there´s in a given project (Guess it "knows" but the data is not available), and neither does it "know" whether a sheet is number X or Y in a set... But please correct me if I´m wrong :beer:
Phillip with Kiwi Codes put together a sheet x of x routine a year or so ago called Sheet Counter. When you get to his site watch the video. Go to his Downloads page if you want it but brace yourself...he wants $5 (USD) for it! Although Aussie dollars might be better deal now?
Couldn't live without my Kiwi Codes Sheet Counter, and for $5 its ridiculously cheap. :thumbsup:
You may have to ask him nicely to supply you with 2012 version.
Pardon my terminology, flashbacks from the days of ADT ;p Here is a link to a video describing the technique, he explains it much better than I could. It's not really a paramteric solution as you still have to manually input the total sheet count one time in the project info section. It involves creating a shared parameter and using it in a project parameter:
REVIT does not come installed with a title block family parameter that displays how many sheets are in a sheet set. In fact REVIT doesn...
I am trying to give a lil something back to this community for all the help I have received, but maybe it's too soon for that. Appologies if I have caused any confusion.
Kiwi Codes has a solution for that too? I keep seeing this tool come into the convo and looking forward to the day I can get off 2010.
How do I make a schedule of title blocks for each sheet. I started with a Sheet Index, but I can't find a parameter for the title block. I'm trying to...
Ok I want in titleblock -View Name- but it looks like it is impossible to do that, guess because you can have multiple views on one sheet. What is solution...
