Which is Better way?
    Hi Guys,
    I want to create multi type family file in Revit MEP. i have lot confusions to create these kind of objects because of changes in lengths and visibility.
    mainly i using Referance Lines and Dimensions(Length) parameter for this changes and some times i using visibilty parameter also...
    My Question is which one is the best way to change and modify the family file?
    For creating multi family type the Main problems is come in voids only... i dont know which is the best best way visibilty or dimension parameter...
    :crazy:
    Originally posted by prawin92 View Post
    ...For creating multi family type the Main problems is come in voids only... i dont know which is the best best way visibilty or dimension parameter...
    Voids do not have the option to use visibility parameters... So to answer your question directly: Dimensions.
    However, it´s impossible to give you an answer that fits all situations, there are workarounds, and different families would require different solutions. If you´re working on something specific, then let us know exactly what you are unsure of.... :beer:
      Thanks for ur Reply....
      currently i'm working in display cases (speciality euipment family). i want to ceate different sizes case into one file... and the piping and electrical connectin locations are changes as per size of cases...
        Should be doable... upload the current state of your work, and let us know where you get stuck - I for one, would be happy to take a look at it.
          Sorry for long reply and thank you for your help... i'm doing Very Confidential project... So i cant send files.... i try to give some sample files which are already
          released in market...
          Thank you munkholm... i will be send soon
            This is the image file which i am creating....Click image for larger version
