We are using a filter to change the cut pattern for a wall that is 1 Hour Rated. It's pretty simple, and the filter works fine. The oddity that i noticed is that the hatch pattern changes orientation depending on if it is a Coarse view or a Medium/Fine View. If it is Coarse, the hatch is aligned to the Wall element as it defined in the pattern, but if it is Medium or Fine, the hatch acts more like a Fill Region typically does and is does not align. I've attached a couple of screenshots. Has anyone experienced?
Changing a wall's cut pattern with a filter oddity
Yes. The materials for the layers of the wall needs a fill pattern set to align with the model. It doesn't have to show, however, if you use a white color, or space it ridiculously far apart. I use this instead of the coarse scale fill pattern... fewer things to chase down when a change occurs.Greg McDowell Jr
about.me/GMcDowellJr
What Greg said. Ive made every fill pattern that has to go in to a Wall, set to Align with Model, even if they arent meant to be. It sort of stinks for Brick, as i really like the exterior pattern on brick to stay oriented to the View (it makes my detail components look better, since mine are unhatched hollow detail components), but oh well.
I'm using the filters to show fire rated walls in plans. It works great in coarse, the pattern follows the wall, but when we switch to fine the pattern...June 8, 2011, 08:40 PM
Shot in the dark....
So in AutoCAD (I know, bad thing to start with), we have a block for which we place "over" our 2d sound...-
Channel: MEP - General
January 21, 2013, 10:46 PM -
Hey guys, I'm new to this forum.
I just got the Revit 2014 and been having problems with hatching/patterns. I think my main issues for now...June 2, 2013, 09:15 PM -
I responded to a thread at Linked In this morning, something I almost never do. I find LI too frustrating to spend much time there. Regardless, the sought...
Channel: Blog Feeds
September 13, 2016, 05:15 PM -
hi, i was wondering how to darken a fill pattern? i attached a picture below.
the pattern was a hatch i found online. i tried modifying it,...February 13, 2013, 06:28 PM
