I am working in Revit Architecture with an MEP file linked in. In reviewing my warnings I came across this:
"The default system 'Default Domestic Cold Water' is now over 50 elements. To improve performance, Revit is no longer calculating the critical path pressure drop and the more complex duct sizing has been disabled. If you want to use these features, you must define logical systems in the model instead of using the default system."
An MEP colleague tells me that this warning is due to the fact that I have more than 50 plumbing fixtures on one system. I do, in fact, have many plumbing fixtures modeled into my Arch file. However, being in Revit Arch I do not believe I have the ability to change the system these fixtures are on. At least, in the properties the System Type & Name parameters are grayed out.
Does anyone know how I can fix this warning?
