Parameter that displays which view a generic annotation is placed in??
    Wondering if there is a way for Revit to tell me and schedule which views my generic annotations are placed in.
    for example I have a symbol placed in the East Elevation, In the schedule I want a column that tells me that this symbol lives in the east elevation. I don't want it to be driven by a comment or something I need to manually enter...any ideas??
    The result i'm going for is just to be able to filter my generic annotation schedule by view name, which would be perfect.
    :beer::beer:
    thanks for any feedback
    Not nativity in Revit. You can schedule generic annotations in a note block, but can only select fields from generic annotations and project information. W use a custom parameter to show our generic annotation sheet notes in the right views. Add it to the Autodesk Ideas list and maybe it will get implemented someday.
    Julie Kidder
    Architect + BIM Director
      Can you tell me more about your custom parameter? was it made by a third party app or hack? what does it do exactly?
      right now I have a trial version of CTC express tools 'Spreadsheet Link Express' and it has a laundry list of fields available for Generic Annotations, one of the them being 'owner view', which is exactly what I want. If I could just get that to be an available field in native revit I would be set!
ID:	391512Click image for larger version
        Nothing fancy, just an instance parameter that we manually put the sheet number into, then we filter by that. You could probably write a dynamo script to do it for you, but you'd have to keep running it when you added new instances.
        The owner view could be coming from the workset - annotation objects are on their view's workset but you can't get to that nativity.
        Julie Kidder
