Been hacking at this for a few months now. :banghead:
We have a second story floor plan with the underlay set to the reflected ceiling plan of the stated level. Problem is that none of the ceilings, bulkheads or fixtures shows up in die underlay.
When the view was first setup, it was working fine.
This is a multi story building and all the other levels are working fine with the underlay set to the reflected ceiling plan of the level.
Anny ideas as to what can be causing this.
Need do get this one out for submission.
Thank you
Thank you
