Assemblies cut pattern!
    Hi all.
    I am new to assemblies, why when an assembly is cut does it not show the materials cut pattern?
    (I have detail level set to fine...)
    Does one have manually draw filled regions to indicate materials cut?
    Thanks,
    Craig
    Make sure that the elements do show a hatch pattern in section views before making the assembly. The issue might not have anything to do with the Assembly tool, but with the materials specified for the elements.
      Thanks Alfredo
      Exactly the solution!
