Is it possible to change the workplane of a workplane based family in Revit API (any version)? I can see the parameter and get it's string value, but I can't set it to anything. I can't find any other way to access or change the workplane, is it possible?
Change work plane?
I am not knowledgeable enough to know where to look for this, but I'm guessing there is a directive that is reserved for setting object workplanes, as opposed to just setting the parameter's value like a variable..Carl - Architect, BIM Manager, Father, Husband, Coach, Player, Disc Tosser, Driver... not necessarily in that order.
Not to my knowledge no. But, the API isn't my strongest part...
Looking at it logically you shouldn't be directly looking for changing the workplane. If I want to do this natively I first have to disassociate and then reassociate by manually appointing a new workplane. So the API-version should be:
- Unhost from workplane and make it re-applicable
- List possible workplanes (but that might give you an enormous list)
- Filter out usual suspects based on selection criteria (for instance the level that the element was on in the first place)
- Pick one...Martijn de Riet
Hi.
I wont to change some custom instance parameters for members of group from my addin.
Command work, but after it successfully...-
Channel: Third party Add-Ins, API and R&D
October 25, 2011, 02:45 PM -
It would be really great to have an API script set the work plane via shortcut keys.
For example, while working in a 3D view, have 4 work planes...-
March 7, 2013, 02:05 PM -
Is it possible via API to get all warnings in a document? I have looked at the failures API but it appears to only allow you to create new ones or to...
September 17, 2012, 08:49 PM -
I found an old AUGI post by Steve Stafford that states
But I can't get my family to do that.
The Origin of my family a Reference...-
January 21, 2019, 06:23 PM -
Is there any way to extract parameters and their associated formulas from a family? I'm doing some reverse engineering and it would make life a lot easier...
August 12, 2014, 03:33 PM -
