I'm working with a model from an architect in Revit 2012, and i'm trying to use parts to create a more detailed 4d schedule (I use Navisworks for 4d). I'm having a couple of different issues that I can't figure out.
1. Is there a way to create custom parameters of the original object that will push to the parts?
ex. i would give an exterior wall custom parameters to define elevation (eg east) so that i can make a search set in Navis that corresponds
it would be much easier if all of the exterior wall's parts picked up certain parameters from its original geometry because i will use about 4 custom parameters per model (level, sequence, elevation, building)
2. Is there a way to control the ID number of parts based on their original geometry. My goal with this is once the architect updates his model i want to be able to push my custom parameters back into the correct parts. However, it appears that the ID number would be different each time the model is updated, and parts are created. (I would actually need some help with the whole process of pushing custom parameters into an existing model based on ID, but want to see if the parts thing is possible before spending too much time on it)
Also, I'm pretty new to Revit. I'm completely willing to use formulas or whatever it takes to make this work...I'll just need a little more help with it.
Thanks in advance for any help.
